“You’ve confusing impedance with sensitivity. With lower sensitivity headphones, you might need an amp. With lower sensitivity headphones you might need to turn the volume up more. Going from 16 ohm to 32 ohm drops the volume 3dB. Thats nothing! The threshold of detectability is usually around 1 dB for most people. But that doesn’t mean lower impedance works better. It doesn’t as I’ve shown above. It just means that if you get headphones that need an amp, you might need to get an amp. But you can still easily drive higher impedance headphones provided you pick ones with suitable sensitivity such that an amp isn’t needed. And in fact doing so will give you slightly better performance then going with very low impedance headphones.”
It isn’t just about the impedance of the headphones though.
Impedance total= output impedance of player * headphone impedance/(output impedance of player + headphone impedance) The greatest amount of power is transfered when the headphone impedance matches the output impedance of the player.
Higher impedance headphones also tend to have a lower sensitivity.
Message Edited by JK98 on 01-25-2010 07:07 PM
