Can WD Smartware activate and function on a network that does not touch the internet?
I don’t want to purchase the pro version if it will not work.
Do you have SmartWare now? Do You have a WD My Cloud or other WD Device? If you have SmartWare have you opened it and read the Help information that is provided?
If you have it, open the Help tab>Backup>Upgrade to the WD SmartWare Pro software? and read the information provided.
Here is a link to the User Manual.
https://support.wdc.com/knowledgebase/answer.aspx?ID=15136
