# Can read, cant save to MyBook HD
**URL:** <https://forums.sandisk.com/t/can-read-cant-save-to-mybook-hd/398859>\
**Category:** External SSD for Windows\
**Created:** [July 6, 2015, 7:21am UTC](https://forums.sandisk.com/t/can-read-cant-save-to-mybook-hd/398859 "2015-07-06T07:21:14Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![Grond](https://avatars.discourse-cdn.com/v4/letter/g/e495f1/32.png) [@Grond](https://forums.sandisk.com/u/Grond)\
**Post date:** [July 6, 2015, 7:21am UTC](https://forums.sandisk.com/t/can-read-cant-save-to-mybook-hd/398859/1 "2015-07-06T07:21:14Z")
</div>
I purchased my WD My Book 2TB external HD 10/2014.&nbsp; It is being used mainly for bulk storage (photos and music) with my Dell Latitude E6440 laptop.&nbsp; I am not using it to back up my laptop.&nbsp; My operating system is Windows 8.1 and I am running Office 2013.
The WD HD was working well, I could save files to the HD and extract files all ok.&nbsp; But recently (2 months ago?) I could no longer save anything to this HD and could not change files on it.&nbsp; I am still able to access everything on the HD normally, I can do a back up of the HD using another HD, but I am not able to save anything new onto my WD HD.
If I try to save something to the drive it comes up with Error 0x8000FFFF
There is over 1TB of space on this drive, so it is not ‘full’.
Is this a software update issue on my laptop?&nbsp; If so, what updates do I need.
I have looked at all the trouble shooter titles and many community posts and none of them seem to cover this problem (that I could see… and I did many pages!).&nbsp; Thanks.
**Author:** ![ArMak](https://sea2.discourse-cdn.com/sandisk/user_avatar/forums.sandisk.com/armak/32/45499_2.png) [@ArMak](https://forums.sandisk.com/u/ArMak)\
**Post date:** [July 7, 2015, 7:52pm UTC](https://forums.sandisk.com/t/can-read-cant-save-to-mybook-hd/398859/2 "2015-07-07T19:52:08Z")
</div>
Hello and welcome to the WD community.
Have you tried to connect the device to a different computer to see if you get the same results when you try to copy to it? Hope this helps narrow down the causes.
**Post date:** [August 10, 2015, 1:50am UTC](https://forums.sandisk.com/t/can-read-cant-save-to-mybook-hd/398859/3 "2015-08-10T01:50:13Z")
</div>
Hi ArMak,
Yes, I tried plugging the drive into another computer but get the same issue.&nbsp; The drive appears to be working normally in all ways, except it doesnt allow me to save anything new or re-save any modified files.
**Post date:** [August 10, 2015, 9:07pm UTC](https://forums.sandisk.com/t/can-read-cant-save-to-mybook-hd/398859/4 "2015-08-10T21:07:22Z")
</div>
By any change was this drive used on a Mac and then on a Windows? If this is not the case, try to check the permissions on the unit it could be a permission issue.
