Can I listen while charging?
I am new to the Fuze and want ot know if I can listen to songs while I am charging it?
If yes How?
Thanks in advance for your help!
Regards,
Aashtee
Yes you can listen to the Fuze while it is being charged on an AC or car adaptor.
While the device is connected via its umbilical to the USB port on your PC, it is in slave mode, and the controls are disabled.
Basically, if the screen shows that the device sees data, it says “connected”, and the controls are disabled.  You can stream music from the device via your computer, though…
Bob  :smileyvery-happy:
