Can a MSC protocol Sansa Express organize by track number?
Ever since I switched from MTP to MSC, none of my albums are numbered by track order.
Is there any way to get a  MSC Sansa to recognize track numbere metadata?
As long as the track number is set correctly in an ID3v2.3 or ID3v1 tag, it should be recognized regardless.
So does the MTP standard have anything to do with the ID3 tag?
Some of my files are ID3 v2.2.
Would the MTP support those?
  • Thanks
Also, how do you switch from MSC back to MTP?
The instructions that got me to MSC don’t offer an option for MTP.
Thanks.
The same procedure you use for switching to MSC can be reversed; just select MTP Device instead of USB Mass Storage Device.
