I have downloaded and successfully installed the firmware update but the player is still in Arabic. I followed the info on settings and choosing the line with FM in it but after the second line with FM, there are no other options and it does not change to English. Am I missing a step? It would be helpful if the solution was put in the manual since this seems to be an issue and if we cannot read Arabic (or whatever foreign language it slips into) we cannot choose a menu option correctly. Any solution? Thanks.
Under settings, look for the letters “FM” above should be Language option.
Worked perfectly and quickly. Thank you very much!
