Hi
the computer recognize the player , media playerrecognize it too, I can sync with the player not a problem.
Where I have a problem is the option to create “folder hierarchy on device”, and “start sync when device connect” are both greyed out, so I can not disable “create folder hierarchy” or enable the “start sync when devices connect”
I have windows xp pro, windows media player 11 with all updates etc…
Please and thank you
Gilles
