c200 v2 does not have a recovery mode...
i tried to put it on recovery mode by enabling the hold… pressing on the ‘rec’ button and plugging it  to a computer…
maybe they changed it… i don’t know…
Try turning on hold and then holding down the square select button in the center of the control area.   This allow my usb port to see the device even though it is dead in the water.
The ‘rec’ botton doesn’t mean recovery, it means ‘record’.  It’s a hotkey for the record feature.  I think you have to hold it down for 2 seconds or something like that, then it will bring you right into the record mode.
