I am using a Linksys Wireless G Travel Router to listen to internet radio but it frequently stops playing to buffer. Is there any way to modify the settings to prevent the interuption/buffering? I am using firmware ZAP 1.0.1.27236r.
Thanks
Thanks
If you note a lot of buffering pauses, it is definitely an issue with the WiFi, local network or upstream ISP network.
I assume the Linksys G Travel Router you have is WRT54GS. I would expect this to be same basic platform as the WRT54G model which I have used. I don’t have any issues with this router at home with high speed cable, but testing at work I have seen throughput degrade when too many people start connecting and causing congestion.
Are you experiencing these problems on your home or travel networks?
