Hello! I have a 2010 WD Caviar Green external hard drive. Model: WD10EADS - 11M2B2.
The port broke and is now lost. I have removed the casing and I’m wondering what my best solution is to access the data on the drive. Is it possible to get new housing or a new port? I’m not an expert at electronics but feel confident I could solder a new port on if I could find one (I’ve been hoping to find the one that broke) I’m not sure where to source this. I’m open to any solutions. Thank you.
we would recommend you contact our 3rd party data recvovery partners to get the data recovered from the drive. (Data Recovery Service Providers)
So i assume it’s the External Enclosure’s USB connector that’s broken and not the actual Hard Drive ?
If so, the 3.5 Hard Drive uses a Standard SATA Connector … and yes you can 3rd Party USB External Enclosures for use with the drive … or simply connect it to any Desktop PC via SATA Cable + Power.
If you want to buy a USB Enclosure … they are sold pretty much everywhere (Computer Stores, Ebay, Amazon etc) for around $20 ~ $30
Vs
3rd Party Data Recovery which will cost you $200 ~ $300 or more !
