Best sync software (2-way for folder of podcasts?)
What are some for doing a two way sync from/with my cip zip and a folder of podcasts on my c:?
The podcasts are NOT in playlists within some other app like itunes or windows media: it’s just a folder of podcasts.
When I delete a podcast on my mp3 player, I want it deleted from the folder on my c:
What’s the best way to do this?
(The windows method which is setup by default with the sansa didn’t reliablly sync back deletes from the player.
Thanks,
Mike
Thanks for the awesome tip!  If I can change a setting on my zip clip and make it be seen as a drive, then syncback and another of tools I already have would work.
I never thought of that!
Thanks!
Mike
PS: I guess the downside is you can’t junk yank it out from the usb plug without risking corruption?  (Need to savely remove?)
MS SyncToy is good, there is also this new freeware: WinDataReflector,  it has two way sync and can automate your sync tasks,
You can download it here: WinDataReflector Free File Synchronization
