Battery?
The manual indicates that the battery is not replaceable.  What happens when the battery no longer holds a charge?  How long should the battery last?
The battery in the Clip should provide several years of reliable service.  It is a Lithium Polymer unit, and will serve you well as long as you plug in regularly.
Bob  :wink:
