Battery is not charging.
I had this mp3 for about a month and a half, have not dropped it once or abused it at all but these last two days my mp3 isnt charging at all. I leave it over night with my pc on, but it stays at 29% battery life.
What do I do?
What do I do?
Disconnect it from your computer count to 10 and plug it back in.  Your computer will get a fresh update on the level reported by your player.
You could also unplug the player and check the battery level the Info section of settings menu.
I have seen on a few occasions that he level may show lower than before.  It may not power back up immediately.  It this happens leave the unit connected to you computer for another 15 minutes.  The screen will come back on.    It most likely will start charging and be back to normal in a couple of hours.
