Battery drain
Can the clip+ ever be shutdown? After charging, I turn it off, don’t use it, and the next day it needs an hour of charging. Is this normal?
Can I ask, how do you know that it needs an hour of charging?  Note that the battery gauge is less than accurate.
And when the player is shut off, it is shut off.
