Hi, I have a My Passport external. I checked the install descriptions for your software and it appears it can not do what I describe below. Is that correct? Thanks, John
Win XP professional use to have an excellent backup. They removed it in Win 7. The XP backup was such that I could see the directories and check a checkbox to back them up. It would automatically select all the subdirectories for backup. I could then go in and uncheck selected subdirectories. I could also check select files within the directory. All this would be remembered. It had the same checkbox approach when restoring files/directories. It needs to backup/restore across a home network to another machine. This is all I need. And for now I need it only for Win 7 (although I probably should be backing up my win 10 notebook). I don’t have the need to store the job which remembers these settings such that I could have different jobs (one job is fine). I took maybe a week and finally found Comodo which can do this but it is unreliable (I did the restore once and it worked and now I can’t restore anything so I have limited backups across machines). I checked AOMEI which is great for image backups (reliable so far) but very cumbersome for file backups as I describe.
