Hi
How do I backup a network drive?
Thanks
Hi
Thanks
Give some details friend like the model number you are refering to
Some wd drive can use Wd smartware or Wd anywhere back up.
I have the same question. I just purchased (from Costco) and set up a WP My Passport Essential SE. The WD software shows only the C:// drive on my work laptop, which is r__unning Windows XP Professional. I would like for the WD automatically to save all of the word processing documents on my P:// drive. I can “copy” and then “paste” in bulk, but I want to take the easy (lazy) route. (If it matters, my firm is running Novell Groupware as its server software.)
I have the same question too.
I’ve bought my passport essential p/n WDBACY5000xx-x with WD smartware ver. 1.4.11 (I’ve updated it so the latest version is 1.4.3.4).
It can’t backup file from network drive. Anybody can help me ?
thank you
Unfortunately, WD Smartware, the version that is bundled with the Passport or WD My Book line cannot backup from a network drive. Even if you update to the latest version of the software, it will not backup from a network drive.
