I just purchased a Passport Essential with SmartWare. I planned on using it at my office to back-up the documents on my network folders and drives. Unfortunately, Smartware doesn’t “see” my network drives - it only sees my internal HDD and two USB flash drives. When I try to simply drag and drop the files in File Directory view, it says I can’t create the folders. Any thoughts?
Maybe you should try contacting WD’s Technical Support about this. You can do so either by phone or email.
http://support.wdc.com/contact/index.asp?lang=en
