# Backing up multiple computers using Smartware possible?
**URL:** <https://forums.sandisk.com/t/backing-up-multiple-computers-using-smartware-possible/401933>\
**Category:** WD Software\
**Created:** [March 21, 2011, 4:58pm UTC](https://forums.sandisk.com/t/backing-up-multiple-computers-using-smartware-possible/401933 "2011-03-21T16:58:22Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![ULJ123](https://avatars.discourse-cdn.com/v4/letter/u/4af34b/32.png) [@ULJ123](https://forums.sandisk.com/u/ULJ123)\
**Post date:** [March 21, 2011, 4:58pm UTC](https://forums.sandisk.com/t/backing-up-multiple-computers-using-smartware-possible/401933/1 "2011-03-21T16:58:22Z")
</div>
I would like to know if it is possible to use Smartware for backing up multiple computers on the same WD My Book Live?
That is, without confilict in the two different backups.
Thanks!
Cheers,
Ulrik
**Author:** ![oxter](https://avatars.discourse-cdn.com/v4/letter/o/8edcca/32.png) [@oxter](https://forums.sandisk.com/u/oxter)\
**Post date:** [March 21, 2011, 7:40pm UTC](https://forums.sandisk.com/t/backing-up-multiple-computers-using-smartware-possible/401933/2 "2011-03-21T19:40:55Z")
</div>
Yes, you can backup multiple computers to your My Book Live using WD Smartware. You just need to install WD Smartware in each of the computer that you wish to backup.
Note: If you one of the computers that you wish to backup is using Mac OS, you will need to use Time Machine instead of WD Smartware.
**Post date:** [March 21, 2011, 8:26pm UTC](https://forums.sandisk.com/t/backing-up-multiple-computers-using-smartware-possible/401933/3 "2011-03-21T20:26:06Z")
</div>
Superb. Thanks for the quick answer, oxter.
