Just completed my first back-up but when I try to open any PDFs, the following message appears on my screen
I have 100s of PDFs, and can’t possibly revisit each one to print as an Adobe PDF. Has the WD community come across this issue and is there a workaround I can apply?
Many thanks for reading my message and for any help you can offer.
Russell
BACKUPS are not standalone files. In order to open a backup, you need to restore it first.
If that’s not what you’re wanting to do, then you probably want to use a SYNC tool instead of Backup tool.
Thank you for explaining this to me - it’s all rather new to me!
cat0w
October 4, 2016, 12:35pm
4
If, .pdf_LAST , as shown at the end of this file that is why it is not opening in Adobe Acrobat DC.
Does a regular .pdf file open for you?
You may want to look at this.
Yes, I can open regular PDFs but I will read through the info on the link
you sent me - many thanks for your help, much appreciated …
