if i buy a b grade sansa fuze off ebay will it still be covered by the manufactures warranty is it worth getting a b grade i can get a brand new 8gb one for £60 or the b grade 8gb for £40 or i could get a brand new sansa clip+ 8gb for £40 what exactly is a b grade product this is the link it says it comes with manufactures warranty but i dunno
This is an arbitrary grade assigned by the seller only to make you think it’s “just like new”.
A ‘re-furb’ by any other name is still a used unit. Only you can decide if the savings are worrth the risk, but personally I’d get a new unit over a re-furb anytime. It was a little different with the old e200 units; those you could take apart and actually ‘fix’ some things so there was a good chance that with a little fiddling, you wouldn’t end up with a nice shiny black paper-weight. The Fuze isn’t designed to be taken apart, & although it can be done there really isn’t much you can do once you’re in there.
And no, I doubt whether it will be covered under SanDisk’s warranty.
