Only one will scroll at a time (for some reason) but (if you keep the screen on long enough) they will alternate. Give me a few minutes and I’ll double check on mine.
That’s how it works at the moment.
How exactly would you make it selectable? Have an option in the settings to pick which one to scroll?
Also note that if your Artist name, Album name or song title are over a certain character length the Fuze will cut them off (I think the Fuze has a maximum of 30 characters to display for each field). Which is something I found annoying, but was told it was hard to fix and probably wouldn’t happen.
Don’t know how anyone else feels about this, but… I’d prefer that the title scroll be the first default, with artist scroll second. Title/song name is usually what causes me to look and artist can usually be identified by what shows before the scroll.
All things being equal, I’d also like to select which scroll, I’d probably only select the title to scroll, but having it as a user preference would be good. maybe you check which you’d like in ‘preferences’
