styx
1
When I install the Automatic Updater for the e260 I get this :
Exception Processing Message 0xc000613 Parameters 0x75B892A0
0x00000004x75B892A0
0x75B892A0
Cancel - Try Again - Continue
and non of the choices work except Cancel… others just repeat the error message.
Any ideas?
Message Edited by Styx on 06-13-2008 09:19 AM
Message Edited by Styx on 06-13-2008 09:21 AM
styx
2
So no problem adding the new current updates. The MSC drive letters the e260 was
using had been H and I and when I started using the built in card reader it became
H. and so the e260 moved to I and J. Even uninstalling and re-installing the software
did not fix issue so the uninstall has to be leaving something in the resistry that
forces the error upon re-install.
What did work was using Disk Management to reset the e260 to H and I and put the
Card Reader at L. Then I reinstalled the AutoUpdater and all is well. This re-enforces
my belief that an uninstall does not remove all registry entries.
