Nearly half of the audiobooks I download from my computer to my Sandisk Clip+ end up with at least a few chapters out of order. Is this typical? Is there an easy fix for this? Thanks in advance for your help!
And are the ID3 tags for the files in order? You might want to check them out, using MP3Tag (Internet freeware) or another ID3 tag editor. http://www.mp3tag.de/en/
And when editing the tags, you should change (if necessary) the track numbers to reflect leading zeros (01, 02, 02, etc.), and maybe add them to the beginning of the Title field as well. If there are over a hundred chapters, or files you should use need 2 leading zeros (001, 002, 003, etc.).
