Audio Problem with Video
I have a bit of a problem with the audio after a video conversion.
I put a couple of videos on my e260r with no problems. The last video I converted was great except for the audio which has bad sound with the “S” sound. It sounds like the Treble is set way too high and hisses like. The video sounds great when I listen to it on the computer but not on the Sansa. I’ve even tried the “Custom” EQ settings and dropped the high sliders down to the bottom with no results. I’ve tried to do audio repair in my video program on the computer before converting to to the Sansa but no luck there either after conversion.
Any thoughts?
Thanks
Dale
Uninstall any video codec packs you have, and then install K-Lite codec pack (Search google for it!)
