Fuse + will not accept audio book transfers from One Click Digital which is the system my library uses. How can I transfer these books from my PC to my fuse+?
they are likely DRM protected. there should be some software you can download that you will use to sync the books. most libraries use overdive media console. there should be a link somewhere on the library webpage.
