Thanks to the help of this board, I’ve finally been able to transfer audio books to my Sansa 2GB (FW: 1.30A) - now I have the problem that when I go to the Audio Book Folder and select the book …it is in ‘pause’ mode’. … When I press ‘play’ it changes to play mode for a moment then goes back to pause mode. On the very top of the display shows 1/1 next to the battery symbol… I’ve formated my devise with no luck.
It was a license issue. My local library, where I down load the audio books from, has two versions of each book. A FM quality file and a much larger CD quality file for down loads. The FM quality can be used on a laptop with no problems, but only the CD quality files have the necessary ‘hooks’ to transfer the licensing material to a portable device.
