Quickly export NSF data file into PST file formats with all the lotus notes attachments such that – emails, journals, tasks, calendars, address books, notes, and many more just with the utilization of ATS NSF to PST Converter Software.
• Repairs severely corrupted/broken NSF file and retrieves all the lotus notes mailboxes.
• Provides preview features to see recovered NSF file data into HTML and TEXT view.
• Eligible to maintain the original mailbox data structure after the conversion as well as the recovery process.
• Supports all the versions of MS-Outlook, OS-Windows, and Lotus Notes including – latest & earlier versions.
• Capable to export NSF file into various platforms – PST, Office365, MBOX, CSV, HTML, vCard, Live Exchange, EML, EMLX, ICS, MSG file types.
Using NSF to PST Converter tool is the best tool and easiest way for Lotus Notes NSF to Outlook PST Conversion. It is also able to save NSF file data into EML, RTF, PDF, HTML and MSG formats without any intrusion. This tool has a preview facility that shows the preview of all mailbox’s data before finishing the conversion task. The tool supports Lotus Notes 10.0.1, 9.0.1, 9.0, 8.5, 8.0.2, 7.0, 6.5, 6.0 and all versions of Windows OS. For more details, visit: NSF to PST Converter Tool to Convert Lotus Notes NSF Files to PST Format
Follow a small number of trouble-free steps by using eSoftTools Lotus Notes NSF to PST Converter program that efficiently migrates/convert Lotus Notes (NSF) entire mailbox properties including To, Cc, Bcc, Subject, Attachments from NSF to Outlook PST file, EML, MSG, HTML, EMLX, MBOX, ICS, vCard and many more formats. NSF to PST Conversion Software has ability to convert all contacts.nsf file into vCard format and CSV format and the calendars folder of NSF file you can restore into ICS Format with maintains all database. Lotus Notes NSF to PST Conversion Software supports Lotus Notes versions 5, 6, 7, 8 and above, MS Outlook versions 2000, XP, 2003, 2007, 2010, 2013, and 2016 and all Windows OS versions (Windows 95, NT, 98, 2000, XP, Vista, Win7, 8, 8.1 and Windows 10).
Read More - Open NSF file in Outlook 2013, 2016, 2019
There are no size demerits, you can quickly and safely migrate any NSF data files into MS Outlook PST email clients just with the help of Lotus Notes Converter Software that developed by experts and advanced technology.
It automatically restores all the data from corrupted, orphaned, encrypted, and damaged NSF files including – deleted once emails. By using this toolkit, the customer can safely migrate NSF files data into cloud-storage applications such that – Live Exchange Server, Live Outlook, and Office365 accounts without losing any single items.
Transformation from NSF to PST Lotus Notes is required when client needs to change over information from Lotus Notes mail customer to MS Outlook. NSF and PST have distinctive record designs. Without transformation, information in another mail customer is preposterous in one mail customer. In this state, you can utilize the Lotus Notes NSF to PST transformation tool.You can download this product from here:- NSF to PST Converter Tool
