If you are unable to fix highly corrupted Lotus Notes NSF file data then I would like to suggest you to just download the ATS NSF to PST Converter Software which is eligible to perform recovery as well as conversion process without any error. It is designed with various advanced technology and algorithm that’s why it provides user-friendly interface. The software easily recovers all corrupted lotus notes data from NSF file such as – emails, calendars, tasks, notes, drafts, journals, images, and many more. It is eligible to recovers permanently deleted or lost item. The software allows us to convert NSF file into 14+ file formats such as – Outlook PST, MSG, vCard, ICS, MBOX, CSV, HTML, EML, PDF, EMLX files, and other file types. With 100% data accuracy, you can directly export NSF file into cloud-based application such that – Office365 & Live Exchange Server. For checking the performance of this advanced software just utilize the Free Demo Pack that enables you to convert first 25 email items per folder.
Bitdataconversion NSF to PST Conversion Tool is the best application and easiest way for NSF to PST Conversion. Using it, users can convert single as well as multiple(bulk) NSF data files into Outlook PST at the same attempt. This application has a preview facility that shows the preview of all mailbox’s data before finishing the conversion task of the NSF data file to PST. It also able to exports data into EML and MSG formats without any intrusion and supports all versions of Lotus Notes, Domino Server, Outlook, and Windows OS. The tool gives you the safety and guarantees to convert data without any data loss. Download its demo version and users can test the tool and also convert the first 50 data items per folder. It also provides 24*7 technical support.
More details, visit:- Convert NSF to PST
I suggest Softaken Lotus Notes to Outlook Converter to import Lotus Notes NSF email in PST without the loss of any data. The NSF to PST software has several advanced features to complete this process without difficulty and quickly. It has an inbuilt preview option to preview NSF file data before import NSF to PST. info-
Download the best eSoftTools NSF to PST Converter that has been specially made according to users need and capable to convert all lotus notes emails into PST Outlook file With the help of this NSF to PST Conversion Software all users can extract NSF file data and restore NSF file to PST, EML, MSG, HTML and EMLX format along with emails, contacts, calendars, task, notes, inbox items, outbox items, and appointments. You can also convert selective folders by selecting items of NSF file into PST File. The software can be directly installed on Windows operating systems machines up to 10.
Read more - NSF to PST Converter Free Full Version
