[ask] Reformat My Book Essential 1TB to Factory Setting
Hi guys, I need to reformat it to factory setting which usually comes with some apps and folder.
Can anyone help me out? Thanks :cry:
If you reformat the drive, it will erase all the information on the unit. So, being that the case, you will need to download the application from our support page.
Check the  link below for the download page.
http://support.wdc.com/product/download.asp?groupid=125&lang=en
