Guys, there are several speed classes for microsdhc card, class 2, class 4, class 6 and class 8, which one is the minimum speed class to run smoothly with the fuze ? Thanks
I had a class 2 SanDisk card and it worked flawlessly for me.
The “Class” rating of memory cards is only a measure of how fast you can write to the card. MP3 players don’t need fast write speeds, digital cameras do (for things like rapid-succession snapshots, or recording video).
Any speed would be fine in terms of playback, but the higher classes can be much faster when copying files to the card.
I agree I already tried 16gb micro sd in the fuze and it works.
choss!
@keberloo wrote:
I agree I already tried 16gb micro sd in the fuze and it works.choss!
And just what may I ask, does size have to do with speed (the topic of this thread)?
While we are having question time, what is the point of prefixing a thread title with [ask]?
The questionmark at the end of the subject pretty much signals the nature of the post. And if questionmarks are too unclear, ‘[ask]’ should be [question] imo.
@Marvin_Martian,gwk1967, Skinjob, so I assume that every class has the same reading speed ?
Let’s say I play games while hearing music in rockbox firmware, will different classes give different perfomances ? or just the same then ?
@keberloo, what class is yours ?
Yes, but that doesn’t mean that one of the other classes would be even more efficient if the Fuze supports it.
And that’s exactly why I want to find the answer to this question also. Basically, what is the transfer speed of the microSDHC slot in the Fuze? I can’t find this information. Anyone know?
