Are we supposed to use Acronics for backup? It's stuck
Just bought a 5TB Passpoprt.
It took me about 30 min just to figure that WD Backup is no longer supported. WD didn’t bother to show any notification about this.
So I downloaded Acronis for WD, and trying to create my first full backup.
It’s been 5 minutes only saying “calculating the data size…” and “calculating time remaining”.
No progress bar so ZERO clue if it’s stuck or not.
Is this typical? This is a really POOR customer onboarding.
So after some more minutes, it finally started.
Is Acronis a good backup method?
What may I do to keep the full backup and avoid getting it deleted automatically by the program?
PS I just noticed it create a TIBX file. So this means I can’t use Windows Search to find Files on the Hard drive, I suppose, as there’s no straightforward way to view the raw files? That’s kind of a pitfall. Any insight on this?
Hi @davw,
Have you opened a Support Case? If not opened, for more information, please contact the WD Technical Support team for the best assistance and troubleshooting:
https://support-en.wd.com/app/ask
