had a earlier post about a few problems ive had with my clipzip. support said they would replace it- so the question is- has anyone had a clipzip that works properly and isnt riddled with glitches? because i really hope this replacement works the way it should. thank you
Yes. I’ve had mine since they first came out. Not one problem.
I stil have one of the two that I have owned, and it works perfectly.
