Anoyone else having a problem with Sansa Connect not responding when you hook up the usb to the computer that it doesnt open?
If anyone else has this problem can you tell me how to fix it
On occasion, I’ve had to reboot the Connect in order for it to be recognized.
What do you mean by rebooting it rebooting the software?
You need to turn OFF the Connect. You may be putting it in SLEEP mode.
It also sounds like you also need the firmware upgrade.
You can get a jump start on this and other questions by reviewing the FAQs and new User Manual
http://www.sandisk.com/Retail/Default.aspx?CatID=1541
http://www.sandisk.com/Assets/File/pdf/retail/sansaconnect-um.pdf
Message Edited by Greig on 12-03-2007 08:09 AM
