Thanks.
Convert to FLAC. That’s the only lossless compression supported on Clip.
You will probably like FLAC better on your computer as well:
- Good tag support
- Random access (that is, you can drag the progress bar and start mid file)
- better compression.
- much faster compression (I know, not a help if you already have the shn files)
Concert tape traders were the last holdout for shorten, but now most all of them are using FLAC too.
Most of my music is in FLAC. I have a few SHN files left though.
Thanks for the reply my friend. FLAC will do fine.
