Any way to get old laptop with USB2 adapter to recognize clip+?
I put a Dynex USB 2.0 Card Bus Adapter into an old Thinkpad T23 and connected my new 8GB Clip+ but the laptop won’t recognize the player. I’m running XP, Service Pack 3. The laptop is connected to A/C power.
The Dynex manual says that it will run devices that require less than 500mA. Does that rule out the Clip+?
Is there any thing else I can do or add to get the Thinkpad to recognize the player?
I haven’t had a chance to test the player on a desktop or newer laptop, but the Dynex recognizes a flash card reader.
Thanks for any help.
Ellen
What version of Windows Media Player are you running?
I bet the card cant deliver enough power.
You need a Y-USB-Cable where you can feed in external 5V power. Like the cables you get for 2,5" external HDs.
BR
Robert
Actually, I would think that the power needs would be fine.
Is the Clip+ set to MSC mode, in which it is seen as a thumbdrive?  That could help–
Robert, thank you. I think this will do it and will buy a cable to see.
But, do you mean external to the player or to the laptop?
Do I need a Y cable with one mini B male connector and 2 A male connectors?
Or a powered USB hub or other source of power that’s external to the laptop?
(You probably mean the Y cable I described, but I want to be sure.)
Conversionbox: I’m running WMP 10 and yes, I did search the forum and knowledge base,
and google, and other forums, and called SanDisk.
Miikerman: I was using MSC mode.  Tried MTP too, but neither worked.
Thanks very much for your help, everyone.
Ellen
Ah, a powered USB Hub is even a better idea, I think. But it has to be powered.
The other way is such a cable:
And then power the 2nd line by a AC-USB-Power-Adaper:
http://www.thinkgeek.com/computing/9124/
I just took the first 2 found google links, I bet there a cheaper adapters aviable at ebay.
BR Robert
