hi, anyone know how fast the Data rate is when Reading/Writing to the Player (internal Memory)
also when you connect the player and you hav a MSD card in does the card show up in my computer (removeable Disk)
thanks
thanks
In MSC mode, the Sansa will show up as two flash drives, with the first one alphabetically being the internal memory.
In MTP mode, the Sansa will show up as a single device, until you double click on it. Then it will split into two: Internal Memory, and External Memory. To access either section, a second double click opens the root directory.
Bob :smileyvery-happy:
