Amber flashing light
I have a WD netcentre (500Gb) I think.
when I plug in there is a faint high pitched noise. On pressing the front button it boots up and I get a flashing amber light.
I can see the system summary via netmanager, but states no volumes defined, i.e all my directories are not there.
I guess the disc has gone belly up.
Any one any ideas ? or is this a data recovery job
thanks
IanS
Hi, do you have a USB or Ethernet hard drive?
it does have a USB port, and is normall connected trhough ethernet back to wifi router
why ?
an update
company looked at disc and said that the electronics around the disc had gone belly up, but they could see the data on the disc by other means. cost £175 to recover data.
I stripped the disc out of the enclosure and hooked up to old PC as a slave (jumped pins 3&4). Windows does not see the directory structure, but shows up under device manage as correct WD disc.
Duel booted into linux and similar story - disk utility see the disc and would allow me to make a new volume or partition, but again cannot see the directory structure.
I am guessing then that the disc is ok, but somehow the data on it is corrupted in some way.
Also tried in a more new PC in case 320Gb 2nd drive was not supported - same outcome
Question is what to try next ??
any help much appreciated (must say I dont care much for this blue background when typing)
IanS
Ran WinDLG from WD on my more new computer (DELL) - and DELL diagnostics say disc OK
Both the Quick & Extended (winDLG) give a pass ! and health status of GOOD, but no info on Volumes or capacity of the drive in question. C drive shows up ok
Puzzled ???
