Always start-up on the radio
Hi, I’ve been using my express since a couple of months and since I installed the last firmware it behave strangely.  Before, when I shut my express off in a certain mode (radio, music, etc) in start in that same mode, but now it always start in radio mode, and its a bit annoying.  Is there a solution for that problem.
Thank you
The solution is:
The next time that you decided to turn it off…make sure you are in Music playback screen so that it will remember your last thing that you did…if you keep listening to FM all the time then yes it will always pop up to FM.
