All files have doubled and corrupted after 1 day??? Can anyone help please
I have just got a 32gb cruzer blade and copied all my photos, videos and music from my iphone onto it.
It was fine on day 1 now on day 2 went back onto the memory stick and it has doubled up all the files and now says that the file is “either corrupted or the licence has been tampered with and would I like to delete it from my vault”
I just wondered if anyone could offer any advice as to why this has happened and what I can do to rectify this??
Any help would be greatly appreciated
Dan
I recommend backing up all your files, delete the vault file, copy your files back to the USB drive but don’t use SecureDisk, use Windows Explorer.
ok thanks for the advice but is there any way to save the data that is on there at the moment??? cheers
:smiley:
Please, do not grieve, friend: see the link:
http://forums.sandisk.com/t5/SanDisk-SecureAccess-2-0/SanDisk-SecureAccess-V2-0-doesn-t-see-my-encyrpted-Vault-files-i/td-p/327984
Alfred.
:smiley:
Alfred.
:smiley:
Please, do not grieve, friend, see the link:
Alfred.
:smiley:
http://forums.sandisk.com/t5/SanDisk-SecureAccess-2-0/SanDisk-SecureAccess-V2-0-doesn-t-see-my-encyr…
Alfred.
Is this using the vault? If not, I’d run a malware or virus scan on it just to isolate the issue.
:neutral_face:
Hmm…
:neutral_face:
Hmm…
Are you trying to up your post count with these posts? Because they aren’t accomplishing much else.  :neutral_face:
Gracias Ed, podría usted borrar su mensaje, para habilitarme a que yo borre el mío también?
A.
Thanks Ed, could you delete your message, to enable me to I delete mine too?
A.
Think about it. :smiley:
:stuck_out_tongue:
Ed, yo no hice la réplica sobre tú mensaje (creo…).
Yo hice la réplica sobre el primer mensaje de Downtown23, para que tú pudieras borrar el tuyo.
Y luego, así, yo pudiera borrar el mío.
Tú última réplica la hiciste, también sobre este último anterior mensaje, y no sobre el de Downton32.
Ed, I did not reply on you post (I think …).
I made a replica of the first message Downtown23, so you could delete yours.
And then, well, I could delete mine.
You made your last reply, also on this last message above, and not on that of Downton32. Qué lío… :laughing:
