I just downloaded update 1.17 to find that several of the album titles are truncated to 12 characters. What’s worse is that a couple of albums are split into two: one album with the full name and another with only 12 characters. That means I can’t play those albums in their entirety without playing tricks by making a play list.
I upgraded to 1.17 to fix the problem of songs being listed in alphabetic order instead of track order. Now here’s another nasty bug. I’m very diappointed in this “not ready for prime time” product.
When will this bug be fixed?
@miikerman wrote:
What is the player’s USB mode, under System settings, set to: MSC or MTP mode, or the dreaded Auto mode which can fluctuate between the 2?
I believe the Clip Sport is an MSC player only, isn’t it? It doesn’t have a setting for MTP or Auto Defect.
Just letting you know, you’re not alone. I have both album names and band names that have been cut off, and it seems to happen at random, some make it through in tact, others do not, even from the same album. Never had this issue in the older clips and don’t know of a good work around yet.
I resorted to prefacing some album titles with code letters so that the clipsport could at least differentiate them.
Just got a Clip Sport and I have this problem. In Music view all band names and album titles are truncated to 12 characters (but not song titles). I guess this has to be related to improper reading of tags, as in the Folders view everything is fine.
Has anybody found out what’s wrong? I’m on firmware 1.38 (2017 !) so all those firmware updates haven’t fixed it
