Album names have 8-character prefixes
When I add an album to a Clip+ through Windows Explorer under AutoDetect (MTP), the system adds a prefix such as
F20B0000_
followed by the original folder name.  (This does not happen under MSC, but I don’t want to use it because Windows Explorer won’t display the Clip+'s battery status.)
1.  Why does this prefix get added?  What does it represent?  and why doesn’t it always appear?
2.  How can I avoid having such prefixes?
As I understand it, this is a glitch from MTP mode.  And the only way to consistently avoid it is to use MSC mode.
Candidly, I don’t really see that as a sacrifice, as you always can check the battery level on your Clip itself, on the display and under the System information setting for more precise information.
F20B0000_
Here is an explanation from of the Gurus. :wink:
Check this post from one of the gurus here.
