I’m using RealPlayer v. 10.5 to transfer my playlists to Sansa e280. After I’ve added a new clip and just want to update my Playlist, it seems to redo the whole clip list, even though I choose to sync only the one Playlist I want updated. Then I get duplicates of the clips on the Sansa. Why and what should I do?
That is just a limitation of using the RealPlayer to transfer… it just does NOT check for duplicates before transfering.
Use Windows Media Player 11 instead - its automatically set to check for duplicates before transfering… so it will enable you to update the playlist, and the songs on the playlist, without duplicates.
