Adapter plug for the Fuze?
How about making a compact adapter plug that fits into the Fuze so the Fuze can be used with a USB cable that has a mini USB connector?
This doesn’t fit into the bottom of the Fuze, but it seems to me it would serve the same purpose wouldn’t it?
http://www.amazon.com/USB-Female-Mini-Male-Adapter/dp/B0016RNX2I
Unless your goal is simply to do away with the proprietary Sansa cable in lieu of a proprietary Sansa adaptor plug.
"Unless your goal is simply to do away with the proprietary Sansa cable in lieu of a proprietary Sansa adaptor plug. "
That is exactly what I want to do. I want to be able to use the Fuze with an external battery pack without carrying the huge cable that came with the Fuze. I have some very small and compact USB cables with a mini USB connector.
