I recently ordered a combo car charger/FM Transmitter, Item DOTHXXXXFM15, from Accstation.com and on receipt discovered that the docking connector supplied with the unit was not compatible with my e280. Accstation’s website lists the product as being compatible with Sansa e200 and e200R series players and also the c100 series. Accstation.com authorized it’s return promptly and I do not anticipate a problem with a refund. I believe that the same issue would exist for c100 series units.
I dont think the pin configuration for the iPod and those used by Sansa are the same. What more on the other devices they listed as compatible.
The length of the connector plug is not same. Ipod’s plug is .5mm longer. Hope that helps.
Message Edited by hckrs2k3 on 07-24-2009 09:24 AM
