I am having difficulty accessing the shuffle mode screen. I get to the music screen & press the select button & the shuffle screen only appears for a second & then goes back to the screen showing whatever is playing. I’ve got hundreds of songs on this thing but have only been able to listen to the same 10!!!
Have you got shuffle turned on in Settings?
This may have something to do with it. From the User’s Manual, Page 17:
Quick Tips:
1. When on the home level menu, swiping vertically will give a preview of the content
contained in that area. For example, the Music section will display the album art for
the 10 most recent songs played. Videos, photos, and podcasts will also display
the thumbnails for the 10 most recently played files in those categories.
2. No matter where you are in the user interface, pressing and holding the back
button on the upper left corner of the touchpad area will return the device to the
home level.
If this is indeed the issue you are experiencing, it sounds like you just need to go back one more level.
