AC outlet charger options
I recently bought a Sansa Clip and wondered if I could use the AC power charger from my previous MP3 player.   The “plug” fits the player and has these specs on it:
Input 100-240 V 50/60 Hz  200mA
Output 5V -1000mA  (L.PS.)
Thank you for any imput!   If I could use it, I would enjoy the $40 savings :slight_smile:
I’m not sure what the “(L.PS.)” means, but it sounds like the charger should be fine (I assume that the charger has a standard mini-B USB connection on th Clip end).  And you’re right:  save the $!
I’m not sure what the “(L.PS.)” means, but it sounds like the charger should be fine (I assume that the charger has a standard mini-B USB connection on the Clip end).  And you’re right:  save the $!
Thank you for your feedback, Miikerman.  I think the LPS probably is some trademark but I am not fluent in “electric” I thought I’d throw it in the mix! :slight_smile:
Cool.  The major issue to always be sure of:  that the charger’s voltage is 5V (more could blow your device out); you’re fine there.  A high amperage (as distinct from voltage) is fine:  the Clip just takes what it needs.
