AC charging
I want to charge my clip with an AC wall outlet. Does any body Know the specs.? I have a 5V–1A output charger that I use for my iPAQ. Will this work or is the output too high?
Thanks for your help.
That should be fine.  Higher amperage is fine (the player just uses what it needs), it’s too low an amperage that would be an issue.  And the correct voltage, 5 V, is crucial.
