I’ve had my Sandisk Fuze since May, and until now, it has performed exactly as I wanted it to. This morning, I started having a problem regarding AC charging.
Basically, while connected to the AC adapter, it now behaves as if it is plugged into my computer. It displays the “Connected” image, and stops any playback. This hasn’t happened before, I’ve normally been able to charge while connected to the AC adapter and play at the same time.
I have an 8 GB Fuze v2. I have not changed anything with the device, I haven’t altered the firmware, I hadn’t even connected it to a computer since the last time I was successfully using the AC adapter.
