Hi!
Any idea if the « Rugged Case WD Nomad » fits a « WD My Passeport Edge » ?
P/N : WDBJBH5000ABK-03
Can’t find the information anywhere… =(
Hi!
The edge is supposed to be smaller than regular passports so it should work just fine
don’t have an edge to double check for you but you can contact WD to get the manufacturer’s opinion
I did order it this morning, hoping everything will work as it should.
I’ll confirm that everything fits nicely as soon as it arrive.
Thanks for the quick answer.
Take care.
Any Time.
Did it work?
