5ghz not showing on my MacBookPro
I have som problems when trying to watch HD video from my drive. It starts and stops, and is not smooth at all. I was thinking that 2.4ghz could be overcrowded and wanted to change to 5ghz. I can see the 5ghz SSID on my phone, but in my Mac i can’t
I can see other 5ghz networks around me, including on in my apartment, but not the one that I want to…
any suggestions ?
Hi NorwegianTiger,
Maybe you should try contacting WD’s Technical Support about this.
The link below will allow you to call support.
Where did you found a menu for 5 GHz in the admin settings? I don’t have it.
I only can setup this here:
My WiFi also does not work as ist should after firmware upgrade to 1.07.02:
